New Arrival: High Performance KVM Over Wi-Fi
Squishy Mango | MT300N-V2 | Shadow | AR300M16
by GL.iNet
Original price USD3.99 - Original price USD3.99
USD3.99
USD3.99 - USD3.99
Current price USD3.99
⚠️BEFORE YOU BUY
Bulk Order
Squishy is modeled after two of GL.iNet's most beloved mini routers, Mango and Shadow. Mango Squishy will brighten up your day with its energetic yellow body. Shadow Squishy will blend into your workspace and melt your heart with its cuteness in the most unexpected times.
- Colors are randomized and therefore not selectable.
- Multifunctional - Squishy can be used as gifts, display samples, stress relievers, and collectibles.
- Easy to Clean - Squishy is made from high-quality TPR material. It can be rinsed directly with water.
Caution:
1. Keep away from children under 7 years of age
2. Play under parental supervision and avoid swallowing small parts.
3. Made with certified safe, non-toxic, and environmentally friendly materials.
4. Avoid high temperatures or direct sunlight exposure for long periods of time.
5. Avoid aggressive pulling or yanking.
6. A slight odor may be present after unpacking.
  • CPU:
  • Memory / Storage:  /
  • Protocol:
  • Wi-Fi Speed:
  • Antennas:
  • Cellular:
  • Battery:
  • TF Card Slot:
  • USB Port:
  • Ethernet Port:
  • Ethernet Speed:
  • Power Input:
  • Power Consumption:
  • Dimension / Weight:  /
Product Initial Setup Guide
