Limited-Time Flash Sale: Save Up to 20%!
GL-S200 Thread Border Router
by GL.iNet
Original price USD0.00 - Original price USD0.00
USD99.00
USD99.00 - USD99.00
Current price USD99.00
⚠️BEFORE YOU BUY
Bulk Order
MEET GL-S200
Dual-Protocol Thread Border Router
Low Power Thread Mesh & BLE to MQTT IoT Network
GL-S200 is a Thread Border Router designed for users to host and manage low power and reliable IoT mesh networks. The device supports both Thread and BLE protocols, and it comes with an optional pre-configured Thread development board for a simplified integration process to IoT devices.
Supports Thread & BLE
Supports BLE to MQTT
Optional pre-configured Thread development board
User-friendly topology management interface
Learn More
Integrate Thread into IoT Devices
The GL-S200 Gateway offers a convenient way to integrate the Thread protocol into IoT devices. It offers an optional pre-configured Thread Development Board that enables data transfer with the gateway's Thread protocol via UART, SPI, and I2C integration with IoT end devices. Additionally, an optional testing module is also available, it includes a variety of sensors and control interfaces, such as push & turn dial, RGB light, PIR, Humidity, Temperature, and atmospheric pressure.
Thread Topology Interface
The GL-S200 Admin Panel provides a user-friendly topology interface for users to maintain an organized and manageable overview of their complex IoT networks.
Thread & BLE Dual-protocol
The GL-S200 Thread Border Router is capable of running both Thread and BLE protocols simultaneously. Thread protocol is optimal under high density networks while avoiding network congestion, and BLE is capable of connecting to devices at greater distances, effectively providing users with the flexibility to connect to a wide range of devices.
Minimal Latency Pathfinding Coordination
GL-S200 supports both device-to-device and device-to-cloud connectivity. Its Thread protocol allows the deployment of multiple Thread Border Routers and seeks the most efficient path using the fewest nodes for connecting to the Internet. It uses multiple border routers simultaneously to reduce the latency of large IoT networks. IoT devices within the network will automatically seek the router with the lowest latency for connecting to external networks.
Secure Your Smart Home and IoT Devices
GL-S200 supports Thread and BLE protocols, it is designed to maintain multiple protocols connection at the same time, and the device is compatible with most smart home IoT devices. All Thread networks supports Advanced Encryption Standard (AES) encryption and phone authentication to provide multi-layers of security for the connected devices.
The Future-proof Smart Home Gateway for Home Automation
Built-in Security
GL-S200 supports AES encryption and phone authentication to build a secure access control network for smart homes and smart buildings.
Low Energy Footprint
Built on the power-efficient IEEE 802.15.4 MAC/PHY to connect an ecosystem of low power products to each other, ideal for lighting control, energy management, smart home appliances control etc.
Open IPv6-based Protocol
IPv6 features auto-configuration and multicasting which allows one-to-many communication between devices. It runs on end-to-end encryption to offer powerful network security.
GL-S200 runs on GL.iNet's proprietary firmware based on OpenWrt, presenting a user-friendly interface to set up Thread networks and offers an extensive degree of customization, with users being able to choose from OpenWrt's 5000+ open-source ready-made plug-ins.
DNS over TLS & DNS over HTTPS
GL-S200 supports both DNS over TLS and DNS over HTTPS to enhance network privacy and security, providing users with the flexibility to choose between encryption depending on the network type. DNS over TLS uses encryption to secure DNS communications, while DNS over HTTPS uses the HTTPS protocol for an additional layer of security.
OpenVPN/WireGuard
GL-S200 is pre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. It automatically encrypts all network traffic within the connected network, including smart home devices that are not capable of running VPN encryption independently.
S200 Webui
Remote Access and Management
GL-S200 comes with GL.iNet's GoodCloud remote device management platform, providing users with remote access to the device admin panel and data usage monitoring. It also enables batch device management, firmware updates, and configuration. The GoodCloud platform also provides device analytics and notifications for status updates, enabling users to manage devices efficiently.
OpenWrt Pre-installed
OpenWrt
Pre-installed
Type-C Power Input
Type-C
Power Input
Thread
Thread
Real-time Scanning
Real-time
Scanning
BLE 5.0
BLE 5.0
  • CPU: QCA9531, @650MHz
  • Memory / Storage: DDR2 128MB / NAND Flash 128MB
  • Protocol: Supports Thread | Supports BLE 5.0 | Supports Wi-Fi 802.11b/g/n (2.4GHz)
  • Wi-Fi Speed: 150Mbps (2.4GHz)
  • Antennas: 1 x Module Onboard Antenna (BLE)、2 x External Antenna (Wi-Fi & Thread)
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: N/A
  • Ethernet Port: 1 x WAN port, 1 x LAN port
  • Ethernet Speed: 10/100Mbps
  • Power Input: Type-C, 5V/2A
  • Power Consumption: <4W
  • Dimension / Weight: 118 x 85 x 30mm / 108 g
  • GL-S200 THREAD Border Router
  • Power Adapter
  • External Cable
  • User Manual & Warranty Card
Product Initial Setup Guide
