Power Adapter Cable - Type-C PD to DC 5.5mm x 2.5mm (65W Max)
by GL.iNet
Sold out
Original price USD9.99 - Original price USD9.99
USD9.99
USD9.99 - USD9.99
Current price USD9.99
Bulk Order
Description
Built-in PD Emulator Trigger with Type-C female. Seamless compatibility for Spitz Plus (GL-X2000) and Spitz AX (GL-X3000). It supports up to 65W maximum power output (backward compatible with 45W/30W/20W/18W), perfectly matching the power demands of your router for home, office, or travel use.
Specifications
Parameter
Details & Key Points
Input
Type-C Female, PD Charger
Output
DC 5.5mm x 2.5mm, Up to 20V (backward compatible with 15V/12V/9V)
Power
Supports up to 65W (backward compatible with 45W/30W/20W/18W)
Voltage
Requires PD charger with 9V-20V output
Cable Length
27cm
Compatibility
Spitz Plus (GL-X2000)Spitz AX (GL-X3000)
Caution
⚠️ Critical Notes for Safe & Stable Use
  1. PD Charger Wattage Requirement: Must use a 30W or higher PD charger (matches X2000/X3000’s 12V/2.5A = 30W rated power). Ensures sufficient redundancy and stable activation of the PD trigger chip (avoids unstable power or boot failure).
  2. Voltage Compatibility Confirmation:
    • GL-X2000: 9~36V voltage range → PD 20V output is fully compatible.
    • GL-X3000: 9~36V voltage range → PD 20V output is fully compatible.
  3. Mandatory PD Charger Use: Relies on PD trigger chip for high-power conversion. Non-PD chargers may cause unstable transmission or failure to work. It also supports 5V/1A or 2A charging.
