Smart 2.5G Port Flexibility
Brume 3 comes with three versatile 2.5G Ethernet ports, giving you a fast and flexible foundation for any wired setup. The dedicated WAN port delivers full 2.5G performance and can also be reassigned as a LAN port, while LAN1 and LAN2 each support full 2.5G speeds as well, allowing you to tailor your network exactly the way you need it.
Whether you're optimizing for speed, expanding your wired devices, or setting up a secure home gateway, Brume 3 keeps everything running smoothly and efficiently.
