Limited-Time Flash Sale: Save Up to 20%!
by GL.iNet
Original price USD119.99 - Original price USD119.99
USD119.99
USD119.99 - USD119.99
Current price USD119.99
Choose a Type
⚠️BEFORE YOU BUY
Bulk Order
Wi-Fi 6 Gigabit Wireless Router
MEET Slate AX
Wi-Fi 6 Gigabit Router in Your Pocket
Wi-Fi 6 Travel Router
Slate AX (GL-AXT1800) is our first Wi-Fi 6 travel router that comes with IPQ6000 1.2GHz quad-core processor. With the latest Wi-Fi 6 technology, you can enjoy more capacity for connected devices and faster wireless speed on the road or at home.
Max. 600 Mbps (2.4GHz) + 1200 Mbps (5GHz) Fast Wi-Fi Speeds
OpenVPN speed up to 500 Mbps (with DCO support); WireGuard speed up to 550 Mbps
Support Openwrt 21.02 , DFS and file sharing
Learn More
Runs on OpenWrt 21.02
Slate AX runs on the latest OpenWrt 21.02 operating system (Kernel version 4.4.60), with mass device connection capabilities, and significantly reduced signal interference. You can customize the router and install applications based on your preferences.
Fast and Secure Browsing with VPN Encryption
Supporting OpenVPN and WireGuard®, Slate AX allows you to browse securely when on public wi-fi, work remotely when abroad, and access geo-restricted sites. Set up your VPN on the admin panel and shield the network on all connected devices. With saved settings, you won't have to set it up again every time.
WireGuard
Max. 550Mbps
OpenVPN-DOC
Max. 500Mbps
30+ Commercial VPN Provider
Sophisticated Hardware Design
Slate AX is engineered to be a powerful and efficiently compact device. Its retractable antennas are both powerful and space-efficient for travel-friendly storage, and its enclosure holes pattern is both eye-catching and perfect for heat dissipation.
The device comes with a powerful CPU, Type-C power supply, USB 3.0 port, 3 gigabit ports, and a TF card slot that supports up to 512GB. Slate AX is ideal for file sharing and installing third-party applications that suit your needs.
GL-AXT1800 Ports
Portable Wi-Fi 6 Router
Slate AX offers powerful Wi-Fi 6 network connection with a dual-band combined Wi-Fi speed of 1800 Mbps (600 Mbps for 2.4GHz and 1200 Mbps for 5GHz). Enhance Wi-Fi performance with MU-MIMO, OFDMA, BSS color and able to connect to up to 120 devices simultaneously.
Our local network storage feature supports SAMBA and WebDav protocol. By plugging an external USB hard disc into the router, you can create a private network to store and share your documents. No matter for work or family, you can benefit from easy file access. Save space on your devices by storing photos and videos on the network; you can also use NAS to backup all your files to prevent data loss.
Portable Wi-Fi for Frequent Travelers
Protect Your Privacy on Public Wi-Fi Network
Wi-Fi 6 Coverage for Your Sweet Home
DFS Certification in US, UK, Europe & Japan*
Slate AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications. The selection of additional channels can lower network congestion under high density network environments.
*5G Wi-Fi Band 2 (5250Hz-5350Hz) is currently unavailable in Japan
Use Slate AX together with the GL-M2 Development Board which is designed to connect you to a 5G network and give you the internet you deserve. With a built-in SIM card slot, the GL-M2 Development Board serves as a 5G modem for your router to get your internet up and running, whether you are residing in a remote area with no internet access or traveling on the road. Even better, the GL-M2 Development Board features multi-WAN, supporting failover and load balancing to keep you connected at all times.
Learn More
WPA3 protocol
DNS over HTTPS & DNS over TLS
AdGuard Home
IPv6
Featured as the Best Travel Router of 2024 by PCguide
Selling itself as a portable router, it holds up well against standard gaming router options, which we wouldn’t expect from something designed on the go.
Slate AX (GL-AXT1800) Reviews
  • Video 1
    Set Up Secure VPN in Minutes with GL.iNet Routers!
  • Video 1
    Why You Need a Pocket Router: Hotels, Airports, Airplanes, Cruise Ships - Stay Connected Anywhere!
  • Video 1
    Travel Router - Do you really need it? GL.inet 1800 Review
  • Video 1
    Slate AX Travel Router to Fool your Boss and Stay Safe
  • Video 1
    Wireless Charging That Doesn’t Suck - Qi 2
  • Video 2
    Travel VPN WIFI 6 Router : GL-iNet Slate AX Pocket Size
  • Video 3
    GL.iNet GL-MT3000 and GL-AXT1800 Wi-Fi 6 Travel Routers
  • Video 3
    Product Review GL.iNet Slate AX Travel Router
  • Video 3
    Slate AXT1800 WiFi 6 Router Review | Compact Yet Powerful Router You Can Buy In 2022!
  • Video 3
  • Video 3
    Melhor Router para Viagem com Wifi 6! Segurança e Privacidade! | GL.iNet Slate AX (GL-AXT1800)
  • Video 3
    Use Home IP Address While Traveling with GL.iNet AX Slate, Opal, and WireGuard® VPN
  • Video 3
    GL.iNet GL-SFT1200 vs GL-AXT1800: Which Router is Best for Travel?
  • Video 3
    Schnelle Reise-Router - GL.iNet Slate AX und Slate Plus im Doppeltest
  • Video 3
    Which GL.iNet travel router is best for you?
  • Video 3
    Why This WiFi 6 Router Could SAVE Your Next Trip! GL.inet AXT1800
  • Video 3
    Gl Inet Slate AX GL AXT1800 Unbox Setup Captive Portals
  • Video 3
    Must-haves for IAM pros working remotely | Ep. 155
  • Video 3
    Ce Que J'Emmène Toujours en Vacances - Gadgets Indispensables pour l'Été!
  • Video 3
    DAS sagt KEINER über STARLINK MINI im Wohnmobil
  • Video 3
    WHY YOU NEED A TRAVEL ROUTER - HOTEL'S , CRUISE SHIPS, AIRPORTS...
  • Video 3
    The TRUTH About Travel Routers: What You Need to Know!
    Wi-Fi 6
    Wi-Fi 6
    Gigabit Ethernet
    Gigabit
    Ethernet
    Type-C Power Port
    Type-C
    Power Port
    USB 3.0 Port
    USB 3.0
    Port
    OpenWrt Pre-installed
    OpenWrt
    Pre-installed
    VPN Client/Server
    VPN Client /
    Server
    AdGuard Home
    AdGuard
    Home
    AdGuard Home
    Multi-User
    MIMO
    DFS
    DFS
    Local Network Storage
    Network
    Storage
    • CPU: IPQ6000 Quad-core,@1.2 GHz
    • Memory / Storage: DDR3L 512MB / NAND Flash 128MB
    • Protocol:  IEEE 802.11a/b/g/n/ac/ax
    • Wi-Fi Speed: 600Mbps (2.4GHz), 1200Mbps(5GHz)
    • Antennas: 2 x undetachable external Wi-Fi antennas
    • Cellular: N/A
    • Battery: N/A
    • TF Card Slot: 1 x microSD card slot
    • USB Port: 1 x USB 3.0
    • Ethernet Port: 1 x WAN port, 2x LAN ports
    • Ethernet Speed: 10/100/1000Mbps
    • Power Input: Type-C, 5V/4A
    • Power Consumption: <8.75W
    • Dimension / Weight: 125 x 82 x 36mm / 245 g
    • Slate AX (GL-AXT1800) Wireless Router (2-year Warranty)
    • Ethernet cable
    • User Manual
    • Power adapter with US (default) or UK or EU or AU plug
    Frequently Bought Together🎁
    Product Initial Setup Guide
