May Carnival Deals-Up to 29% off!
Travel Gadget Organizer Pouch Case | Hard Drive Bag | For chargers, cables, travel routers
by GL.iNet
Original price USD15.99 - Original price USD15.99
USD15.99
USD15.99 - USD15.99
Current price USD15.99
Color: Blue
Bulk Order
 The best travel organizer for electronics! Hard Carrying Case replacement for GL-BE3600, GL-MT3000, GL-AXT1800, GL-MT1300, GL-SFT1200, GL-E750, GL-AR750S, GL-AR750, GL-MT300N-V2, and GL-AR300M, GL-X750V2. Perfect for travel, keep your devices organized.
Product Description
• Features: Case is made of supreme quality, durable EVA, crush resistant, anti-shock, water resistant material provides adequate protection from bumps, scratches and splashes.
• With Internal mesh pocket can store other accessories.
• Internal Dimension: 5.9 x 4.3 x 2.7 inch, External Dimension: 6.3x 4.7 x 2.8 inch
• Durable Exterior Material: Polyester Fiber with soft pad inserted. The durable material can protect the device and accessories inside. The protection from the soft pad reduces the impact of falling and shocks.
Physical Features
• Colour: Grey/Black
• External Size: 16.2cm*11.8cm*6.9cm / 6.3in*4.7in*2.8in (L*W*H)
  • CPU: N/A
  • Memory / Storage: N/A / N/A
  • Protocol: N/A
  • Wi-Fi Speed: N/A
  • Antennas: N/A
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: N/A
  • Ethernet Port: N/A
  • Ethernet Speed: N/A
  • Power Input: N/A
  • Power Consumption: N/A
  • Dimension / Weight: 162 x 118 x 69 mm / 165 g
  • 1 x GL.iNet travel organizer pouch case (electronics accessories are not included)
Product Initial Setup Guide
