by GL.iNet
Super Early Bird--Earliest shipping time: Early April, 2026
Pre-order--Earliest shipping time: Mid April, 2026
2nd Batch Pre-order--Earliest shipping time: End of April, 2026
Pre-order
Original price USD399.99 - Original price USD399.99
USD279.00
USD279.00 - USD369.00
Current price USD279.00
Choose a Module
Choose a Type
⚠️BEFORE YOU BUY
  • If you wish to purchase the NA version, please note it in your order or contact cs@gl-inet.com after payment.
Bulk Order
Meet Mudi 7
Product Code GL-E5800NA GL-E5800EU
WCDMA B1 / B5 / B8
Next-Gen Connectivity
Anytime, on the go
Up to 13.5h Battery Life: 5380mAh capacity with 24W PD fast charging
Tri-band
Wi-Fi 7
5765Mbps
6GHz
2882Mbps
5GHz
688Mbps
2.4GHz
5G Connectivity
2.8” LCD Touchscreen
Dual SIM Dual Standby
Up to 13.5hrs Run Time
2 USB-C Ports
2.5G LAN/WAN Port
High-speed VPN
OpenVPN-DCO
700+ Mbps
WireGuard®
600+ Mbps
eSIM
Activate, connect, share
5G meets tri-band Wi-Fi 7
Secure, stable, and always on
slide 1 to 2 of 4
Dual-SIM backup, eSIM flexibility
Switch networks instantly
Mudi 7 delivers the stability you need via dual-SIM dual-standby, and the freedom you want with built-in eSIM—letting you switch carriers instantly without ever touching a physical card.
One-tap carrier connection
Seamless SIM & eSIM toggle
Connect your way, with versatility
slide 1 to 2 of 4
Stop struggling with outlets
Equipped with a 5380mAh battery, Mudi 7 doesn't rely on power outlets. It recharges via 24W PD fast charging, minimizing downtime.
Mudi 7 (GL-E5800) Reviews
    The Newest Travel Routers...
What Beta Testers are Saying
tar_xvf
What I love most is the ecosystem—I host my own VPN server on GL-iNet hardware at home and connect the Mudi 7 to it from wherever I am. It’s the ultimate setup for working abroad. The built-in LAN port is also a huge plus for privacy; by hardwiring my laptop, I can kill the wireless radios and keep my location completely off the grid.
@tar_xvf
amuzyche
This seemingly mobile router provides connectivity not only for laptops and TVs but for an entire smart home ecosystem. Handling work by day, 4K streaming by night, and simultaneous climate/lighting control is effortless.
@amuzyche
Vulcan
I can’t say enough good things about the Mudi 7. I needed something dependable for work on the go, but it’s quickly turned into our family’s all-around internet solution.
@Vulcan
mmavis29
Pocket‑friendly and simple to set up, it pairs solid hardware and mature software with quick, reliable Wi‑Fi and consistently strong VPN performance. The long battery life means fewer outlets and more productivity on the go. In short, it’s the ultimate mobile router—a must‑have travel companion.
@mmavis29
_DaNobody
The most underrated accessory included with each Mudi 7 is the travel case. It protected my Mudi 7 from the heavy rain while only having surface moisture on the outside. Unfortunately the rain got to my books and soaked them, but the travel case having protected my Mudi 7 gives me peace whenever I travel with it. Absolute 10/10 in my opinion.
@_DaNobody
admonstrator
It is most effective during on-site client visits: When I'm working directly at a server room rack, I use it to hook up to the internet on my own. This bypasses the need for local firewall configurations, and the built-in VPN ensures that I always have secure access to our company servers. I can easily access my secure data and tools without compromising the client's infrastructure.
@admonstrator
tomp5138
We had 36 tablets, 14 laptops and 1 printer connected over WiFi to the mudi, plus a Poe switch on the ethernet port connected to 6 Poe cameras and a comet Poe. Spectators were able to live stream the event from the cameras and get real time results, all passed through the mudi. And just to add this was all on battery the entire time.
@tomp5138
mniko_tech
Battery life has been excellent – it easily lasts through long travel days and extended usage, which is exactly what I was hoping for in a mobile router. Performance has been stable, and I especially appreciate the support for the latest channels, which helps maintain strong and reliable connections in different environments.
@mniko_tech
jl_blackbriar
Arrived at an Airbnb, first thing unpacked is the Mudi7.
@jl_blackbriar
Earendilsi
At home, I use it in tethering mode with my Flint 3, ensuring a reliable backup connection ready to take over if my fiber line goes down. As always, GL‑iNet’s interface is outstanding: clean, intuitive, and powerful.
@Earendilsi
bonedaddy4538
The Mudi 7 is a game changing device that puts other 5G hotspots to shame. The features are unmatched and will perform in the most demanding use-cases.
@bonedaddy4538
Up to 4.67 Gbps 5G NR
Up to 4.67 Gbps
5G NR
Tri-band Wi-Fi 7 BE5800
Tri-band Wi-Fi 7
BE5800*
2.5Gbps Ethernet Port
2.5 Gbps
Ethernet Port
10 Gbps USB 3.1
10 Gbps
USB 3.1
OpenWrt Pre-installed
OpenWrt
Support
VPN Client / Server
VPN Client /
Server
eSIM Support
eSIM Support
Fast Charging
Fast Charging
*Dual-band Simultaneous (DBS) Wi-Fi 7 BE5800: 2.4GHz Only, 5GHz Only, 6GHz Only, 2.4GHz+5GHz, 2.4GHz+6GHz
Technical Specifications
Mudi 7(GL-E5800) 5G NR Frequency Bands
WCDMA B1 / B5 / B8
2 x Nano SIM Card Slots
1 x Onboard eSIM Chipset
2 x TS-9 Ports
1 x Power Button
1 x Reset Button
Memory/Storage LPDDR4X 2GB / 8GB eMMC
eSIM 1 x Onboard eSIM
Built-in Battery 3.85V/5380mAh/20.72Wh
Power Consumption <30W
Tools & Downloadables Datasheet | App | Unboxing | Tutorials | Media Kit
  • CPU: Qualcomm, Quad-core @2.2GHz
  • Memory / Storage:  /
  • 5G Platform: Qualcomm Dragonwing MBB Gen 3 (X72)
  • Protocol: 802.11a/b/g/n/ac/ax/be
  • Wi-Fi Speed:  688Mbps (2.4GHz), 2882Mbps (5GHz), 5764Mbps (6GHz)
  • Antennas: 8 x Internal Antennas (6 x cellular antennas, 2 x 2.4GHz & 5GHz & 6GHz Wi-Fi antennas)
  • Cellular: 5G NR
  • Battery: 3.85V/5380mAh/20.72Wh
  • TF Card Slot: N/A
  • USB Port: 1
  • Ethernet Port: 1
  • Ethernet Speed: 100/1000/2500Mbps
  • Power Input: USB PD/PPS 5-12V, 30W Max.
  • Power Consumption:  <30W
  • Dimension / Weight: 157 x 75 x 22.8mm / 300 g
  • 1 x Mudi 7 (GL-E5800) Router
  • 1 x Battery pack
  • 1 x Travel pouch
  • 1 x 10Gbps USB-C cable
  • 1 x User Manual
Product Initial Setup Guide
