by GL.iNet
Original price USD179.99 - Original price USD179.99
USD179.99
USD179.99 - USD179.99
Current price USD179.99
Choose a Plug
Wi-Fi 6
Unleash mobility, free from Ethernet cable
2.22-inch Touchscreen
4K Video Passthrough
Quad Core
CPU
32GB eMMC
DDR3L 1GB
Ultra-low Latency
Gigabit LAN (1Gbps)
Self-hosted Server
Why Do I Need a KVM
Why Do I Need a KVM
The Comet Pro
Wi-Fi 6
Comet Pro is the first desktop KVM device to support both 2.4GHz and 5GHz Wi-Fi bands. Connect your GL.iNet Comet Pro (GL-RM10) to your Wi-Fi network without needing a LAN connection, redefining flexibility in remote access. Users can now manage systems without the need to connect physical network cables, unlike traditional KVM solutions. Additionally, the Comet Pro allows for network failover with both Wi-Fi and ethernet capabilities to improve your uptime stability.
Dual Band Wi-Fi 6
Total System Control
Accessories
PoE Splitter
PoE Splitter
Travel Case
Travel Case
TechRadar
TechRadar
Comet Pro Product Reviews
    I NEEDED to Fix her Internet!
    What Beta Tester are Saying
    The product feels premium to touch and the UI is very good, both on device and the web UI. The ease of use is astonishing. I could set the whole thing up in 5 minutes without having to read or google something AND without having ever used a KVM before.
    @uranioh
    I have loved working with this device, its made remoting onto any of my servers or end user computers miles easier and when using the web app, everything is really smooth. I experienced no latency issues or connectivity issues whilst carrying out any of my testing.
    @Zwytch
    As an IT field engineer, the Comet Pro has become my go-to tool for accessing servers and systems that lack out-of-band management. It’s compact, reliable, and surprisingly versatile.
    @OzTech74L
    The GL.iNet Comet Pro really delivers on what modern remote access users want. The 2.2-inch touchscreen is surprisingly handy for quick status checks and setup without opening a browser. Features like Virtual Media/ISO mounting, BIOS-level control, and remote file copying make it far more flexible than most remote KVM boxes.
    @Mniko
    Compare KVM
    Home Lab Comet (GL-RM1)
    Comet
     (GL-RM1)
    KVM over Internet
    Comet PoE
     (GL-RM1PE)
    KVM over PoE
    Comet Pro
     (GL-RM10)
    KVM over Wi-Fi 6
    Display
    4K@30FPS
    4K@30FPS
    4K@30FPS
    Latency Latency
    Latency Latency
    30-60ms*
    Latency Latency
    30-60ms*
    Latency Latency
    30-60ms*
    Two-way Audio Two-way Audio
    HD Passthrough HD Passthrough
    Display Screen Display Screen
    2.22" touchscreen
    System & Connectivity
    Processor Processor
    Processor Processor
    Quad-core Cortex-A7
    Processor Processor
    Quad-core Cortex-A53
    Processor Processor
    DDR3L 1GB / 8GB eMMC
    DDR3L 1GB / 32GB eMMC
    Wi-Fi Wi-Fi
    Wi-Fi Wi-Fi
    Wi-Fi Wi-Fi
    Wi-Fi Wi-Fi
    2.4GHz: 286Mbps
    5GHz: 286Mbps
    LAN Port LAN Port
    LAN Port LAN Port
    1Gbps
    LAN Port LAN Port
    1Gbps
    LAN Port LAN Port
    1Gbps
    Power Input Power Input
    Type-C, 5V/2A
    Ethernet (PoE) / Type-C,
    5V/2A, PD-compatible
    Type-C, 5V/2A,
    PD-compatible
    Dimensions Dimensions
    80 x 60 x 17.5mm / 85g
    102 x 70 x 22mm / 140g
    93 x 84 x 47mm / 170g
    Wi-Fi 6
    Wi-Fi 6
    4K@30FPS Video Resolution
    4K@30FPS
    Video Resolution
    H.264 hardware encoding
    with 30-60ms latency
    BIOS Access
    BIOS Access
    USB 2.0 External Extension
    USB 2.0
    External Extension
    Two-way Audio
    Two-way Audio
    APP or Browser Access
    APP/Browser Access
    Gigabit Ethernet
    Gigabit
    Ethernet
    Technical Specifications
    Operating System Linux 6.1
    CPU Quad Core ARM Cortex-A53
    Resolution 4K@30FPS
    1x Gigabit Ethernet port
    1x HD In
    1x HD Out
    1x USB 2.0 Type-A
