CES Only (Jan 6–9): Add to cart & enjoy 10% OFF on selected items.
Refurbished | Dual-band Mini VPN Router | GL-AR750S-Ext
by GL.iNet
Sold out
Original price USD79.90
Original price USD79.90 - Original price USD79.90
Current price USD24.90
USD24.90 - USD24.90
Style: US Plug
⚠️BEFORE YOU BUY
Bulk Order
Slate / GL-AR750S-Ext
GL-AR750S-Ext
MEET SLATE
Gigabit Wireless Router for Security-savvy Travelers
Keep Snoopers Off Your Wi-Fi Network
Keep your Internet connection private with multiple VPN protocols support. GL.iNet Slate provides the best encryption and authentication with OpenVPN. Meanwhile, WireGuard® gives the privacy-minded users a fast and simple VPN that utilizes state-of-the-art cryptography.
Max. 300Mbps (2.4GHz) + 433 Mbps (5GHz) Wi-Fi Speed
128 GB Max MicroSD
3 x Gigabit Ports
Learn More
Your Security is Our Priority
Added Security to Help You Stay Secure on Public Wi-Fi
Your Personal Wi-Fi Router
  • Fast and Reliable Network: Video chat with your friend half way across the world.
  • Gigabit Ethernet: 3 gigabit ports for quick file sharing between other gigabit-enabled devices.
  • Data Backup: Share a hard drive with everyone on your Wi-Fi network.
Your Privacy is Safe with Us
Slate keep your Internet connection private with multiple VPN protocols support. It provides the best encryption and authentication with OpenVPN. Meanwhile, WireGuard gives the privacy-minded users a fast and simple VPN that utilizes state-of-the-art cryptography. You can even configure your router to act as a VPN server and you can access the server whenever you want.
VPN
30+ VPN Service Provider
The Gigabit Routers that Made for Portability
Slate is designed for frequent travelers, it is therefore both compact and lightweight. It can easily slip into a backpack, or even your pocket and take it with you anywhere. It also comes with a USB port for connecting a 3G/4G USB modem.
ENJOY REMOTE WORKING
Connect Multiple Workplaces Seamlessly
Slate brings all your workplaces under a digital roof with a secure VPN. Connecting your global offices with Slate so the staff from all locations can communicate with each other remotely and all data is shared securely. You don't need to think about how your workplaces might change your network preference.
WIRELESS SHARING
Share Files Across Devices
Slate has a built-in MicroSD slot that has a 128GB capacity. With the extra storage, you can create a local drive to store and download files on your laptop and other compatible devices as long as it is connected to the Wi-Fi.
Mask Your Online Identity with VPN
Apart from its powerful built-in firewall, Slate also support VPN, WireGuard and DNS server to level up your online security. With brand-new Web UI 3.0, you can set up VPN server easily. It can be configured as VPN server and allow users to access files securely as if they are at home.
WireGuard
Max. 68Mbps
OpenVPN
Max. 17Mbps
WebUI
Cloudflare
ENCRYPTED DNS WITH CLOUDFLARE
Cloudflare DNS over TLS
DNS over TLS is a security protocol for encrypting and wrapping Domain Name System (DNS) queries and answers via the Transport Layer Security (TLS) protocol. The goal of the method is to increase user privacy and security by preventing eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Cloudflare X GL.iNet
Timeless Design for the Digital Age
Turning a hand-drawn design to a fully functional prototype is not an easy task, hundreds of hours have been put into the project to make it happen. We take pride in all of our products and we hope you would enjoy the product as much as we do.
Design flow
OpenWrt Pre-installed
OpenWrt
Pre-installed
Gigabit Ethernet
Gigabit
Ethernet
External Storage
External
Storage
Dual-band Wi-Fi
Dual-band
Wi-Fi
Dual Flash
Dual
Flash
VPN Server/Client
VPN Server/
Client
High Speed
High Speed
Powerful SoC
Powerful SoC
  • CPU: QCA9563, @775MHz SoC
  • Memory / Storage: DDR2 128MB / Dual Flash 16MB Nor + 128MB Nand Flash
  • Protocol: IEEE 802.11a/b/g/n/ac
  • Wi-Fi Speed: 300Mbps (2.4GHz) + 433Mbps (5GHz)
  • Antennas: 2 x undetachable external antennas
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: 1 x microSD card slot
  • USB Port: 1 x USB 2.0
  • Ethernet Port: 1 WAN port, 2 LAN ports
  • Ethernet Speed: 10/100/1000
  • Power Input: MicroUSB, 5V/2A
  • Power Consumption: < 6W
  • Dimension / Weight: 100 x 68 x 24mm / 86 g
  • Slate (GL-AR750S-Ext) (3-month Warranty)
  • USB cable
  • Ethernet cable
  • 5V/2A power adapter with US (default) or UK or EU plug
Product Initial Setup Guide
