New Year Deals:Save Up To 20% !
Convexa-B (GL-B1300) Smart Home Gateway | OpenWrt | Dual-band | Gigabit
by GL.iNet
Sold out
Original price USD89.00 - Original price USD99.00
USD89.00
USD89.00 - USD89.00
Current price USD89.00
Choose a Power Adapter
⚠️BEFORE YOU BUY
Bulk Order
Convexa-B (GL-B1300) is a remarkable product in order to satisfy the wireless Internet access demand for both commercial and home users.
It will be your best choice for enjoying wireless Internet surfing. It provides the best encryption and authentication with OpenVPN. Meanwhile, WireGuard® gives privacy-minded users a fast and simple VPN that utilizes state-of-the-art cryptographic algorithms. With our brand-new Web UI 3.0, you can set up a VPN server easily and access your files securely via a remote site as if you are at home.
INSTRUCTION: >Go to First Time Setup
Product Description
• Dual Band AC Gigabit Wireless Router: Simultaneous dual-band with wireless speed 400Mbps(2.4G)+867Mbps(5G), Tethering, 3G/4G USB Modem Compatible, Wi-Fi networking.
• Open Source & Programmable: OpenWrt/LEDE pre-installed, backed by software repository.
• Large Storage & Extensibility: DDR3L 256MB RAM / 32MB FLASH ROM, available for hardware DIY.
• Security & Privacy: OpenVPN and WireGuard pre-installed, compatible with 30+ VPN service providers. Cloudflare DNS over TLS can prevent eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Specifications
• WiFi Speed: 400Mbps(2.4G) + 867Mbps(5G) high speed
• CPU: Atheros IPQ4028, Quad-core ARM, 717MHz
• Memory/Storage: DDR3L 256MB RAM / 32MB FLASH ROM
• Ethernet Ports: 3 ports (1 WAN, 2 LAN)
• USB Ports: USB 3.0
• Dimension: 117 x 117 x 35mm
• Weight: 212g
Wall Mount is not included in the package, please order separately here.
  • CPU: IPQ4028 Quad-core ARM, @717MHz SoC
  • Memory / Storage: DDR3L 256MB / NOR Flash 32MB
  • Protocol: IEEE 802.11a/b/g/n/ac
  • Wi-Fi Speed: 400Mbps(2.4G) + 867Mbps(5G)
  • Antennas: Internal antennas
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: 1 x USB 3.0
  • Ethernet Port: 1 x WAN, 2 x LAN
  • Ethernet Speed: 10/100/1000
  • Power Input: DC, 12V/1.5A
  • Power Consumption: <7W
  • Dimension / Weight: 117 x 117 x 35mm / 212 g
  • GL-B1300 Gigabit Wireless Router (1-year Warranty)
  • Ethernet cable
  • User Manual
  • Power adapter with US (default) or UK or EU or AU plug
Product Initial Setup Guide
