Continue to Asia Pacific Store
Or
Select Other Store
Choose your store
United StatesUSD $
EuropeEUR €
United KingdomGBP £
CanadaCAD $
Asia PacificUSD $
Expand Your Control -- Pre-order Comet Now!
Asia Pacific
Choose your store
United StatesUSD $
EuropeEUR €
United KingdomGBP £
CanadaCAD $
Asia PacificUSD $
Pre Order | Slate 7 (GL-BE3600) Dual-band Wi-Fi 7 Travel Router
by GL.iNet
Pre-order--Earliest delivery time: May, 2025
Save 20% Save 20%
Original price USD149.90
Original price USD120.00 - Original price USD149.90
Current price USD120.00
USD120.00 - USD120.00
versions: US
Bulk Order
MEET Slate 7
GL.iNet's First Dual-band Wi-Fi 7 Travel Router
Slate 7 delivers faster speeds and more stable connections, ensuring you stay connected in any environment. Equipped with dual 2.5G high-speed ports, it offers lightning-fast network performance, perfect for demanding tasks such as streaming, gaming, and video calls. Its compact and portable design makes it the ideal choice for business trips and vacations, providing secure internet access wherever you go.
Max. 688 Mbps (2.4GHz) + 2882 Mbps (5GHz) Fast Wi-Fi Speeds
Dual 2.5G WAN Ports (1x WAN and 1x LAN Port)
Supports Type-C power with PD compatibility, featuring a lighter adapter
Wi-Fi 7
3600Mbps
VPN Server
Dual 2.5G Ports
30+ VPN Services
OpenWrt
Pre-installed
PD Power Port
AdGuard Home
DNS
USB 3.0 Port
Wi-Fi 7
5GHz
2882 Mbps
2.4GHz
668 Mbps
Lightning-Fast Wi-Fi 7 Speeds
Powered by Wi-Fi 7 technology, Slate 7 delivers speeds of up to 688 Mbps on 2.4GHz and 2882 Mbps on 5GHz, ensuring smooth 4K video streaming, secure access to public Wi-Fi while traveling, and efficient connectivity for business trips.
Compact Convenience
for Modern Travelers
Measuring just 130 x 91 x 34 mm, its compact design makes it a convenient companion for seamless on-the-go internet access.
A Masterpiece of
Hardware Engineering
Slate 7 features a Type-C power interface with PD compatibility, paired with a lightweight adapter to enhance convenience and portability.
With 1GB of DDR4 memory and 512MB of NAND Flash storage, the Slate 7 ensures smooth operation and ample space for essential configurations.
Secured Internet with your favourite
VPN services
24/7
Slate 7 includes over 30 built-in VPN services, supporting OpenVPN and WireGuard®. This integrated VPN enhances security by encrypting your internet connection, safeguarding sensitive data from threats, and providing safe access to public Wi-Fi. Allowing you to browse, stream, and communicate with peace of mind, no matter where your travels take you.
Connecting to 120+ devices simultaneously
Powered by advanced enhanced OFDMA technology, Slate 7 optimizes bandwidth by efficiently allocating resources across multiple devices, ensuring seamless data transmission with minimal latency. Whether in high-density environments or demanding applications, Slate 7 delivers stable, high-speed connectivity, making it the ideal solution for handling numerous connections without compromise.
Maximize Your Internet Potential with Slate 7
Slate 7 exemplifies the future of wireless technology, offering blazing-fast speeds, diminished latency, and enhanced connectivity in crowded environments through advancements such as Multi-Link Operation (MLO), refined OFDMA, 4K QAM, and preamble puncture.
  • CPU: Qualcomm Quad-core @1.1GHz
  • Memory / Storage: 1GB DDR4 / NAND Flash 512MB
  • Protocol: IEEE 802.11a/b/g/n/ac/ax/be
  • Wi-Fi Speed: 688Mbps (2.4GHz), 2882Mbps (5GHz)
  • Antennas: 2 x foldable external Wi-Fi antennas
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: USB3.0 Type-A
  • Ethernet Port: 1 x 2.5G WAN, 1 x 2.5G LAN
  • Ethernet Speed: WAN Port: 1 x 2.5G Port (10/100/1000/2500Mbps) LAN Port: 1 x 2.5G Port (10/100/1000/2500Mbps)
  • Power Input: Type-C, 5V/3A, 9V/3A, 12V/2.5A
  • Power Consumption: <18W (without USB)
  • Dimension / Weight: 130 x 91 x 34mm (L*W*H) / 295 g
  • 1 x Slate 7 (GL-BE3600) Router
  • 1 x Power Adapter
  • 1 x Ethernet Cable
  • 1 x Warranty Card
  • 1 x User Manual
Product Initial Setup Guide
Customer Reviews
We’re looking for stars!
Let us know what you think
0 of 3 items selected
