Velica (GL-B2200) Tri-band Wireless Mesh Router | OpenWrt | Gigabit | AdGuard Home
DELAY Notice:
-For European Version, we are now conducting a separate firmware optimization test and upgrading it for the European DFS channel. The estimated delivery time would be on April.
Velica (GL-B2200) Tri-band wireless mesh router offers the safest and most customizable Mesh Wi-Fi experience for your home. Velica enabling complete Wi-Fi control with ultimate customization options.
Unlike the other mesh home routers in the market, Velica emphasizes cybersecurity. It provides the best encryption and authentication with OpenVPN & WireGuard®. Keeping your Internet connection private with multiple VPN protocol support.
Product Description
Tri-band Mesh WiFi: Tri-band WiFi with quick speed up to 400Mbps (2.4GHz) + 2x867Mbps (5GHz). Designed for houses to eliminate any WiFi dead zones. Multiple devices are required to extend the WiFi network.
Strengthens Internet Security: OpenVPN and WireGuard pre-installed, compatible with 30+ VPN service providers. Encrypted DNS with Cloudflare or NextDNS. AdGuard Home Supported for blocking ads and online tracking.
Open Source & Programmable: OpenWrt/LEDE pre-installed, backed by software repository. The root access is granted for users to fully customize and optimize the devices.
Smart Home IoT Gateway: Velica can be connected to multiple smart devices instantly with Bluetooth or Zigbee* modules to build a wireless smart home network.
Easy Setup: Users can use the GL.iNet smartphone app to manage the mesh network and VPN services of Velica with a clean and simple user interface.
Specifications
• Wi-Fi Speed: 400Mbps (2.4GHz), 2x867Mbps(5GHz)
• CPU: IPQ4019 Quad-core ARM, @717MHz SoC
• Memory/Storage: DDR3L 512MB / FLASH 16MB NOR FLASH + EMMC 8GB
• Protocol: 802.11a/b/g/n/ac
• Interface: 1 x WAN Ethernet port, 1 x LAN Ethernet port, 2 x LED, 1 x Type-C port for power input.
• Ethernet Port: 2 x 10/100/1000M
• TX power: Max. 23dBm
• Power Input: Type-C, 5V/3A
• Dimension: 151 x 66.5 x 190.5mm
• Weight: 530g
Package Content
• GL-B2200 Tri-band Wireless Gigabit Router (1-year Warranty)
• Power adapter (according to your shipping address)
• Ethernet cable
• User Manual
