Free Shipping On Order Over $100
Refurbished | Amarok (GL-X1200) Industrial IoT Gateway | No WiFi | EP06-E module
by GL.iNet
Save 66% Save 66%
Original price $349.00
Original price $349.00 - Original price $349.00
Current price $120.00
$120.00 - $120.00
Bulk Order
Other Purchase Channels
NA
 Amarok (GL-X1200) is a powerful and stable 4G IoT gateway which without WiFi and is powered by a 4G to network cable. Because of its open-source features, it can be used as an integrated platform for developers and IoT integration development. It also comes with an industrial-grade standard with 5 gigabit Ethernet ports, PoE, 2 SIM card slots, a TF card slot, and a USB 2.0 port.
Product Description
• Enterprise-Grade Standard Hardware: 1x CAT6 LTE module(EP06-E), 2 x SIM card slots, 1 x TF card slot, 1 x USB2.0 port, PoE, 5 x Gigabit ports
Open Source & Programmable: OpenWrt pre-installed. Perfect for developers or IoT integration development.
VPN Client & Server: Compatible with 30+ OpenVPN and WireGuard VPN services.
Specifications
• WiFi Speed: NO WiFi
• CPU: QCA9563, @775MHz SoC
• Memory/Storage: DDR2 128MB/FLASH 16MB + 128MB
• Ethernet Ports: 5 ports (1 WAN, 4 LAN)
• Card Slots: 2 x SIM card slots, 1 x MicroSD card slot
• USB Ports: USB 2.0
• Weight: 1352g
Package Content
• Amarok (GL-X1200) (1-year Warranty)
• 1 x Quectel 4G module pre-installed (EP06-E)
• 4 x 4G LTE external antennas (2 dBi), 2 x 5G&2.4G external antennas (5 dBi), 1 x GPS external antenna
• Ethernet cable
• User manual (in PDF)
• Power adapter (48V/1A is default to support PoE function)
  • Memory / Storage: DDR2 128MB / FLASH 16MB + 128MB
  • Protocol: IEEE 802.11a/b/g/n/ac
  • Wi-Fi Speed: No WiFi
  • Antennas: 4 x 4G LTE external antennas (2 dBi), 2 x 5G&2.4G external antennas (5 dBi), 1 x GPS external antenna
  • Cellular: EP06-E module
  • Battery: NA
  • TF Card Slot: 1 x MicroSD card slot
  • USB Port: USB 2.0
  • Ethernet Port: 5 ports (1 WAN, 4 LAN)
  • Ethernet Speed: 10/100/1000Mbps
  • Power Input: 48V/1A
  • Power Consumption: <15W
  • Dimension / Weight: 240 x 145 x 40mm / 1352 g
  • Ethernet cable
  • EU+UK plug
