Product Description:
Stay in touch with friends and colleagues with this Microrouter USB webcam that features Full HD 1080P and H.264 video compression, give you stunning high quality videos and images. This webcam features an autofocus lens, keeping you always looking sharp even if you are streaming, gaming or video conferencing. There is also a built-in dual noise-canceling microphone that providing studio-quality sound.
Other Key Features:
- Widest Field of View: 360° rotation base with a 90° wide viewing angle reduces dead angles. Excellent for boardroom meetings or teleconferencing.
- USB Plug & Play: Universal USB plug and play format. Easy to use and install. Quick setup just 5 minutes.
- Lighting Corrections & Beauty Effect: Automatic low-light correction provides true-to-life images. Beauty Effect preserves facial details and makes your skin flawless and smooth.
- Highly Compatible: Support GL.iNet routers and compatible with othre major software providers including Skype, Youtube, Facebook, Zoom etc
Webcam
Image sensor: 1/27´´ CMOS Image Sensor
Max Resolution: 1920H* 1080 V
Video Resolution: 1920*1080 1280*720 640*480 320*240
Video Decoding Format: YUY2/MJPG/H.264
Max FPS: 30fps
Exposure Mode: Auto/Manual
White Balance: Auto/Manual
Gain: Auto
Low Brightness Compensation: Auto
Lens
Viewing Angle: Horizontal 90°
TV Distortion: <-1%
Lowest Illumination: <5 Lux
Lens Focal Length: 3.5mm
Lens Aperture: F:2.0mm
Focus Type: Autofocus
Microphone
Directivity: Built-in dual Omni-directional microphone
S/N: 58db
Sensitivity: -32db
Voice Distance: <3m
Frequency Response: 100Hz-10000Hz
Audio
Audio Sampling Rate: 1 Channel 16bit 8k 16k 32k 44.1k 48k
Audio Format: PCM(stereo), compatible UAC1.0
Operating System Compatible:
- Windows XP, Windows 7 (32bit or 64bit), Windows 8, Windows 10
- Android V5.0 or higher OS,
- MAC OS10.6 or higher
USB Interface: USB2.0 and high speed USB
Operation Temperature: -10 °C - 45 °C
Max Operating Current: 230mA
HSF&Safety: ROHS
