US Local Delivery | Opal (GL-SFT1200) Gigabit Wireless Router | Dual Band | OpenWrt | IPv6 | Tor
by GL.iNet
Sold out
$39.90
Opal (GL-SFT1200) is a pocket-sized OpenWrt travel router with best value that offers superb dual-band Wi-Fi performance. It is compactly designed for portable use, which can meet the needs of wireless internet access for small businesses, small departments or business traveler.
Product Description
- Dual-band Wireless Router: Simultaneous dual-band with wireless speed up to 300 Mbps (2.4GHz) + 867 Mbps (5GHz)
- Pocket-friendly: Lightweight design(144.8g) which designed for your next trip or adventure. Alongside its portable, compact design makes it easy to take with you on the go.
- Keep your Internet Safe: IPv6 supported. OpenVPN & WireGuard pre-installed, compatible with 30+ VPN service providers. Pre-installed Tor service. Cloudflare encryption supported to protect the privacy.
- Open Source & Programmable: OpenWrt pre-installed, backed by software repository. Allows you to install different applications, perfect for DIY projects.
*Easytethering NOT supported.
Specifications
- CPU: SF19A28, Dual-Core @1GHz
- Memory/Storage: DDR3 128MB / FLASH 128MB
- Gigabit Ethernet Ports: 3 x 10/100/1000Mbps
- WiFi Speed: 300Mbps(2.4GHz) + 867Mbps(5GHz)
- Interfaces: 1 x WAN Ethernet port, 2 x LAN Ethernet ports, 1 x Type-C Power Input, 1 x Reset button, 1 x Mode switch
- USB Port: 1 x USB 2.0
- Dimension / Weight: 118 x 85 x 30mm, 145g
* GL-SFT1200 does NOT come with MicroSD card slot
Package Content
- Opal (GL-SFT1200) (1-year Warranty)
- User manual
- Ethernet cable
- 5V/3A Type-C power adapter with US (default) or UK or EU or AU plug
