UMINO Cam A4 | Security Battery Camera | Pre-installed 8GB Micro SD Card
by GL.iNet
Save 30%
$59.99
Current price
$41.99
Description:
- 【1080P HD, Clear Night Vision & 2-way Audio】1080P Full HD quality video and image, 130° wide angle can cover more areas and reduce blind spots. With built-in 2 IR LEDs, it can illuminate details up to 32ft (10m) even at night. Auto-switch to night vision when it darks out. Built-in speaker and microphone, allows you to hear and talk directly to your family, pets, or visitors through the Adorcam app.
- 【PIR Sensor, Instant Alerts & Siren Alarm】The PIR motion detection can reduce annoying false alerts caused by rain, snow, insects, and falling leaves. It can help to save the battery. Siren Alarm allows you to warn off thieves with a loud siren that can be controlled remotely. The PIR sensor can send notifications to your smartphone when motion is detected, so you will know what’s happening immediately anywhere at any time, and video clips will be saved to the Micro SD card.
- 【Rechargeable Long Life Battery & Energy Saving Mode】Built-in 5000mAh rechargeable batteries last up to 4 months (10 triggers/day). It allows you to place it indoors and outdoor without worrying about continuously charging it. Enable energy-saving mode in the app to optimize battery life. (NOTE: Press the power button twice to reset the camera, you will hear a notification tone after reset successfully. Please FULLY CHARGE the battery before using it for the first time.)
- 【Easy Installation & IP65 Waterproof】100% wire-free, no power cords or network cables are needed. With the provided bracket and screw, you can install the camera virtually anywhere in less than 5 minutes. IP65 Waterproof, it can withstand rain and temperatures ranging from -4°F to 122°F, endures extreme weather conditions.
- 【APP Control & Pre-installed 8GB Micro SD Card】Access and playback recordings with your smartphone whenever and wherever you are. Supports up to 128GB Micro SD card (pre-installed 8GB SD Card). You can download the important recordings to your smartphone before it overwrites. You can also share video clips or share your account with your family or friends.
