NOTE:
The item is shipping from the local with TAX/VAT & SHIPPING FREE
*European shipping countries: Austria, Belgium, Bulgaria, Croatia, Czechia, Denmark, Estonia, France, Germany, Greece, Hungary, Ireland, Italy, Latvia, Lithuania, Luxembourg, Poland, Portugal, Romania, Slovakia, Spain, Sweden
Product Description:
- 1080P FHD Day and Night Vision: View every event in 1080P resolution day or night.
- 100% Wire-free With Battery: Easy Installation for both indoors or outdoors.
- IP65 Weather Resistant: Install outside without worrying about wet weather.
- Auto Day/Night Vision: Keep watching even when it's dark.
- Two-way Talk: See,hear and speck to visitors from anywhere with the app.
- PIP Motion Detection: Reduce annoying false alerts and save battery.
- Up to 128GB Local Storage: Playback recordings with your smartphone any time securely.
- Encrypted Cloud Storage: Store video clips to the Cloud and view them with the app.
- Function: 1080P
- Resolution: 1080P,1920*1080
- Frame Rate: 15fps
- Image Sensor: GC2063
Lens
- View Angle: 110°
- Lens: M12 Lens
Night Vision
- IR Distance: ≥8 meters
- IR LED: 6 pcs
- Auto Night Vision: Support
Detection
- PIR Detection: Support
- PIR Detection Angle: 110°
- PIR Detection Distance: Max 8 meters
- Sensitivity Adjustment: Support
Alarm
- Message Alert: Support
- Alarm Recording: Support
Wireless
- Wireless Connection: WiFi 802.11b/g/n , 2.4GHz
- Wireless Encryption: WEP, WPA, WPA2
- Wireless Range: Max 80 meters (open space)
Storage
- Local Storage: Support, Max 128GB
- Cloud Storage: Support
App
- APP: Android/iOS
Detection
- Battery: 5000mAh
- Input Voltage: DC5V 2A
- Low Voltage Remind: Support
- Battery Time: 4 months(10 times triggers per day)
Product Function
- Two-way Audio: Support
- Alexa: /
- Google Assistant: /
- Device Sharing: Support
Others
- Operating Temperature: –20°C to 50°C
- 1 x UMINO | AE1 Camera
- 1 x User manual
- 1 x Warranty card
- 3 x Mounting screws and anchors
- 1 x Cable
