UMINO Cam C1 | Security Battery Camera | IP65 Waterproof
NOTE:
The item is shipping from the local with TAX/VAT & SHIPPING FREE
*European shipping countries: Austria, Belgium, Bulgaria, Croatia, Czechia, Denmark, Estonia, France, Germany, Greece, Hungary, Ireland, Italy, Latvia, Lithuania, Luxembourg, Poland, Portugal, Romania, Slovakia, Spain, Sweden
Description:
*SD card is NOT included.
- 【1080P HD Video & Two-way Audio】HD Video Day & Night, Indoors & Outdoors,130°viewing angle.With 2 IR-LED, IR night vision up to 32ft(10m).This Home Security Surveillance Camera Built-in speaker and microphone, allows you to hear and talk directly to your family, pets, or visitors through the Adorcam app(free).
- 【Rechargeable Battery and 100% Wireless】Umino-C1 wireless security camera built-in a 4800mAh rechargeable battery, lasts up to 4 months (10 triggers/day).No power cables or network cables, Easy installed indoor or outdoor. (NOTE: Press the power button twice to reset the camera, you will hear a notification tone after reset successfully. Please FULLY CHARGE the battery before using it for the first time.)
- 【PIR Sensor, Instant Alerts & Siren Alarm】The PIR motion detection can reduce annoying false alerts caused by rain, snow, insects, and falling leaves. It can help to save the battery. Siren Alarm allows you to warn off thieves with a loud siren that can be controlled remotely. The PIR sensor can send notifications to your smartphone when motion is detected, so you will know what’s happening immediately anywhere at any time, and video clips will be saved to the Micro SD card.
- 【Easy Installation & IP65 Waterproof】This home security camera system can be installed in less than five minutes. With the included bracket.Scan the QR code on the box or manual to install the APP, super easy to setup and suitable for iOS & Android smartphones.Perfect for monitoring villa,home,office,shop,hotel,warehouse,school or elsewhere.IP65 Waterproof, it can withstand rain and temperatures ranging from -4°F to 122°F, endures extreme weather conditions.
- 【APP Control 】Access and playback recordings with your smartphone whenever and wherever you are. Supports up to 128GB Micro SD card (NOT included). Download the important recordings to your smartphone before it overwrites. Also share video clips or share your account with your family or friends.This wireless security camera Only works with 2.4GHz WiFi (NOT support 5Gz WiFi).
PACKAGE CONTENTS
Bulk Order
Please contact our customer service team at cs@gl-inet.com for wholesale pricing or other order related questions.
Other Purchase Channels
