EU Local Delivery | Puli (GL-XE300) EG25-G Version
Maximum quantity limit / Order: 100 units
The Puli in this link is only available for the countries listed above. If your country is not on the list, please purchase the Puli EG25-G HERE.
- VAT included
- Fast delivery (Shipping from Germany)
*If customers not from upon countries place the order by mistake, we would ask for the balance or cancellation.
Puli (GL-XE300) is a portable 4G LTE Industrial IoT Gateway that is perfect for home, business, and IoT solutions. With its OpenWrt-supported feature and larger storage compatibility, it is designed for you to develop a DIY IoT project. It also comes with a 5000mAh rechargeable battery, so you can bring it anywhere with you!
Product Description
• Smart 4G to Wi-Fi Converter: Transfer 4G LTE signal to Wi-Fi networking. Up to 300Mbps (2.4GHz) Wi-Fi speeds.
• Built-in 4G LTE Module: Come with a standard SIM card slot that supports the 4G LTE network. It can move into 4G LTE wireless network if the Ethernet Internet fails, in order to ensure constant data transmission. It is compatible with CAT4 and CAT6 modules from various brands.
• Open Source & Programmable: Pre-installed OpenWrt, backed by software repository. Allows you to install different applications, perfect for DIY projects.
• Large Storage & Extensibility: 128MB RAM, 16MB NOR + 128MB NAND Flash, Max. 512GB MicroSD card support. Perfect for further extension and share files across devices.
• Security & Privacy: OpenVPN & WireGuard pre-installed, compatible with 30+ VPN service providers. With our brand-new Web UI 3.0, you can set up VPN server and clients easily. IPv6, WPA3, NextDNS, and Cloudfare supported. Level up your online security.
• Easy Configuration with New Web UI 3.0: The built-in 4G modem supports AT command, manual/automatic dial number, SMS checking, and signal strength checking for better management and configuration.
• GoodCloud System for Monitoring: GoodCloud makes it easy to manage and monitor our devices anytime, anywhere, and multiple GL.iNet devices at the same time. You can view the real-time statistics, set up a VPN server and client, manage the client connection list, and remote SSH to your IoT devices.
Specifications
• WiFi Speed: 300Mbps (2.4GHz)
• CPU: QCA9531, @650MHz Soc
• Memory/Storage: DDR2 128MB / FLASH 16MB + NAND FLASH 128MB
• 4G Antenna: 2 x Internal full-band antennas (700MHz ~ 2.7GHz)
• Protocol: 802.11 b/g/n
• Wi-Fi Antennas: 2 x Internal Antennas
• Ethernet Ports: 2 x 10/100M
• LEDs: 4 x Power supply indicator, 1 x PWR status indicator, 1 x WAN status indicator, 1 x LAN status indicator, 1 x Wireless status indicator, 1 x 3G/4G status indicator
• USB Ports: USB 2.0
• Power Supply: 5V/2A (with battery)
• Power Consumption: <4.4W
• Operating Temperature: 0 ~ 40°C (32 ~ 104°F)
• Storage Temperature: -20 ~ 45°C (-4 ~ 113°F)
• Dimension/Weight: 120 x 74 x 28mm/223.5g
Package Content
• Puli (GL-XE300) (1-year Warranty) X1
• Ethernet cable X1
• User manual X1
• 5V/3A power adapter with US+UK+EU+AU plug X1
Go to > First time setup instruction
*Bulk order please contact Customer Service<cs@gl-inet.com> for quoted price.
PACKAGE CONTENTS
Puli (GL-XE300) (1-year Warranty), Ethernet cable, User manual, and 5V/3A power adapter with US (default) or UK or EU or AU plug
Bulk Order
Please contact our customer service team at cs@gl-inet.com for wholesale pricing or other order related questions.
Other Purchase Channels
Shopee
