Free Shipping On Order Over $200
Mudi (GL-E750 EP06-A) 4G LTE Portable Router | Travel WiFi | Privacy | Tor
by GL.iNet
Save 19% Save 19%
Original price $199.00
Original price $199.00 - Original price $199.00
Current price $161.10
$161.10 - $161.10
Bulk Order
Other Purchase Channels
N/A
Meet Mudi, the best portable 4G LTE privacy router for business and travel. It won the CES 2020 Innovation Awards in the Cybersecurity and Personal Privacy product category. It is also one of our Kickstarter project, which is 100% funded in 8 hoursIt comes with dual-band WiFi with speeds of 300Mbps (2.4GHz) + 433Mbps (5GHz). It is the perfect travel router that supports 30+ VPN service providers. It will be your best travel buddy because of its lightweight (285g) and durable (max. 8 hours working duration) design.
INSTRUCTION: >Go to First Time Setup
Product Description:
  • 4G LTE Smart Router: Transfer 4G LTE signal to WiFi, 300Mbps (2.4GHz) + 433Mbps (5GHz) combined WiFi speed.
  • Open Source & Programmable: OpenWrt pre-installed, extremely extendable in functions.
  • Compact & Durable: 145*77.5*23.5mm compact size and super lightweight (285g), max. 8 hours long working duration makes it perfect for your nice travel mate.
  • Security & Privacy: OpenVPN & WireGuard pre-installed, compatible with 30+ VPN service providers. Tor Supported.
  • Large Storage & Extensibility: DDR2 128MB RAM, 16MB NOR Flash, 128MB NAND Flash, max.128GB MicroSD, USB 2.0 port.
For back up of USB-C Port Replicator, pelase purcahse HERE.
  • CPU: QCA9531, @650MHz SoC
  • Memory / Storage: DDR2 128MB / NOR Flash 16MB + NAND Flash 128MB
  • Protocol: IEEE 802.11a/b/g/n/ac
  • Wi-Fi Speed: 300Mbps (2.4GHz), 433Mbps (5GHz)
  • Antennas: Internal antennas
  • Cellular: PCIe, CAT4 Module (DL/UL 150/50Mbps) or CAT6 Module (DL/UL 300/50Mbps)
  • Battery: Rechargeable 7000mAh Battery
  • TF Card Slot: 1 x microSD card slot
  • USB Port: 1 x USB2.0
  • Ethernet Port: 1 WAN, 1 LAN with USB-C port replicator
  • Ethernet Speed: 100 Mbps FE Port (Supported by docking station)
  • Power Input: Type-C, 5V/2A
  • Power Consumption: <6W
  • Dimension / Weight: 145 x 77.5 x 23.5mm / 285 g
  • Mudi (GL-E750) 4G LTE router (1-year Warranty)
  • USB-C to USB-C cable
  • USB-C to USB-A cable
  • USB-C port replicator
  • Ethernet cable
  • User manual
  • Power adapter (with a US, UK, EU or AU plug)
