Free Shipping On Order Over $200
GL-X750V2 (EP06-A) Smart WiFi | Dual-band Router | 4G LTE
by GL.iNet
Save 26% Save 26%
Original price $169.00
Original price $169.00 - Original price $169.00
Current price $125.10
$125.10 - $125.10
Bulk Order
Other Purchase Channels
Order on Amazon US
Spitz (GL-X750V2) is the advanced version of Spitz (GL-X750). It comes with the redesigned PCBA and optimized antennas to improve the 4G performance. Besides, the EC25-AF version now is ATT certificated. It is also compatible with other major telecommunications companies all over the world with other CAT4 (EC25-E, EC25-AU etc.) or CAT6 (EP06-E) modules.
Product Description:
  • Smart 4G LTE Router: Transfer 4G LTE signal to WiFi, 300Mbps(2.4GHz)+433Mbps(5GHz).
  • Open Source & Programmable: OpenWrt pre-installed, backed by software repository.
  •  VPN Client & Server: Compatible with 30+ OpenVPN and WireGuard VPN services.
  • Large Storage & Extensibility: 128MB RAM, 16MB NOR Flash, up to 128GB MicroSD slot, USB 2.0 port, two Ethernet ports.
A specially designed Wall Mount can be purchased HERE
  • CPU: QCA9531, @650MHz
  • Memory / Storage: DDR2 128MB / NOR Flash 16MB
  • Protocol: IEEE 802.11a/b/g/n/ac
  • Wi-Fi Speed: 300Mbps(2.4GHz), 433Mbps(5GHz)
  • Antennas: 2 detachable external LTE antennas, 2dBi 5G & 2.4G internal Wi-Fi antennas
  • Cellular: Mini PCIe, CAT4 or CAT6
  • Battery: N/A
  • TF Card Slot: 1 microSD card slot
  • USB Port: 1 x USB 2.0
  • Ethernet Port: 1 WAN port, 1 LAN port
  • Ethernet Speed: 10/100Mbps
  • Power Input: DC, 12V/1.5A
  • Power Consumption: <6W
  • Dimension / Weight: 115 x 74 x 22mm / 86 g
  • Spitz (GL-X750V2) 4G LTE wireless router (1-year Warranty)
  • USB cable
  • Ethernet cable
  • User manual
  • 12V/1.5A power adapter with US (default) or UK or EU or AU plug
