Convexa-S (GL-S1300) OpenWrt Home Gateway | Large Storage | Dual-band | Gigabit
Convexa-S (GL-S1300) is a unique smart home gateway with beamforming Wi-Fi, and Bluetooth that can connect all your IoT devices together. More wireless protocols will be added, it can connect to various sensors with Bluetooth.
Users can remotely monitor and control the sensors via the cloud. It also comes with an 8GByte EMMC (Embedded Multi-Media Card) storage, allows you to store your data offline, save bandwidth, and process data locally. With massive space for customized firmware installation, you can also enjoy faster device booting and system processing.
INSTRUCTION: >Go to First Time Setup
Product Description
• Dual Band AC Gigabit Wireless Router: Simultaneous dual-band with wireless speed 400Mbps(2.4G)+867Mbps(5G), Tethering, 3G/4G USB Modem Compatible, Wi-Fi networking.
• Open Source & Programmable: OpenWrt/LEDE pre-installed, backed by software repository.
• Large Storage & Extensibility: DDR3L 512MB RAM / 16MB FLASH ROM, 8GB EMMC, available for hardware DIY.
• Security & Privacy: OpenVPN and WireGuard pre-installed, compatible with 30+ VPN service providers. Cloudflare DNS over TLS can prevent eavesdropping and manipulation of DNS data via man-in-the-middle attacks.
Specifications
• WiFi Speed: 400Mbps(2.4G) + 867Mbps(5G) high speed
• CPU: Qualcomm IPQ4029, Quad-core ARM, @717MHZ
• Memory/Storage: DDR3L 512MB RAM/ 16MB Nor Flash+ 8GB EMMC
• Ethernet Ports: 3 ports (1 WAN, 2 LAN)
• USB Ports: USB3.0
• Dimension: 117 x 117 x 35mm
• Weight: 240g
• IoT module: Built-in BLE. Please contact at <sales@gl-inet.com>
Package Content
• GL-S1300 OpenWrt Home Gateway (1-year Warranty)
• Power adapter(according to your shipping address)
• Ethernet cable
• User Manual
Wall Mount is not included in the package, please order separately here.
Also available on Amazon US / UK / CA / DE / FR / ES / IT / NL / JP / AU / MX with FREE shipping.
