GL-MiFi 4G Portable Router | OpenWrt | 5000mAh Battery | OpenVPN | A Router that You Can Program
Note: The EC25-AU None Battery version and the EC25-J Battery version are currently out of stock and they're already under production. The estimated restock time would be around March.
GL-MiFi is very mini and travel-friendly, which is applicable for small enterprise, business, and family scenarios. It is easily configurable and has a built-in interchangeable module for full optimization. It is compatible with CAT4 and CAT6 modules from various brands. Apart from its powerful built-in firewall, it also supports OpenVPN, WireGuard, and customized DNS servers in order to level up your online security. It's your best choice that provides Internet surfing together with wireless. This 4G smart router transfers 3G/4G LTE signal to WiFi. With embedded OpenWrt system, it is extremely extendable in functions.
Product Description
• Smart 4G to WiFi Converter: Transfer 4G LTE signal to WiFi.
• Open Source & Programmable: OpenWrt pre-installed, extremely extendable in functions.
• Large Storage & Extensibility: 64MB RAM, 16Mb Flash ROM, Max. 128MB MicroSD support
• Security & Privacy: OpenVPN & WireGuard pre-installed, compatible with 30+ VPN service providers.
Specifications
• WiFi Speed: 150Mbps (2.4GHz)
• CPU: AR9331, @400MHz Soc
• Memory/Storage: DDR2 64MB/FLASH 16MB
• Ethernet Ports: 2 ports (1 WAN, 1 LAN)
• USB Ports: USB 2.0
• Weight: 170g
Package Content
• MiFi (GL-MiFi) (1-year Warranty)
• USB cable
• Ethernet cable
• User manual
• 5V/2A power adapter with US (default) or UK or EU or AU plug
Travel Gadget Organizer Pouch Bag is available HERE
Also available on Amazon US / UK / CA / DE / FR / ES / IT / NL / AU / MX with FREE shipping
