Slate Dual-band Mini VPN Router | Portable Usage for Travel, Home, and Business (GL-AR750S-Ext)
NOTE:
The United States LOCAL DELIVERY please direct to > Here
Slate (GL-AR750S-Ext) is our first gigabit router designed for security-savvy traveler. It won the CES 2019 Innovation Awards in the Cybersecurity and Personal Privacy product category. It provides the best encryption and authentication with OpenVPN & WireGuard. With the built-in MicroSD slot that has a 128GB capacity, you can create a local drive to store and download files on your laptop and other compatible devices as long as it is connected to the WiFi. It's your best choice that keeps your Internet connection private with multiple VPN protocols support.
INSTRUCTION: >Go to First Time Setup
Product Description
• Dual-band AC Router: Simultaneous dual-band with wireless speed 300Mbps(2.4GHz)+433Mbps(5GHz).
• Open Source & Programmable: OpenWrt pre-installed, backed by software repository.
• Large Storage & Extensibility: 128MB RAM, 16MB Nor Flash and 128MB Nand Flash. Up to 128GB MicroSD slot, USB 2.0 port, 3 Ethernet ports.
• Security & Privacy: OpenVPN & WireGuard pre-installed, compatible with 30+ VPN service providers.
Specifications
• WiFi Speed: 300Mbps (2.4GHz) + 433Mbps (5GHz)
• CPU: QCA9563, @775MHz SoC
• Memory/Storage: DDR2 128MB/Dual Flash 16MB Nor + 128MB Nand Flash
• Ethernet Ports: 3 ports (1 WAN, 2 LAN)
• USB Ports: USB 2.0
• Weight: 86g
Package Content
• Slate (GL-AR750S-Ext) (1-year Warranty)
• USB cable
• Ethernet cable
• User manual
• 5V/2A power adapter with US (default) or UK or EU or AU plug
Travel Gadget Organizer Pouch Bag is available HERE
A specially designed Wall Mount can be purchased HERE
Also available on Amazon US / UK / CA / DE / FR / ES / IT / NL / JP / AU / SG / MX with FREE shipping
