Creta (GL-AR750) Travel AC Router | 30+ VPN | File Sharing
by GL.iNet
Sold out
$49.90
Creta (GL-AR750) is a small dual-band wireless router that is perfect for traveling or home use. It also comes with a 128GB MicroSD card slot that comes in handy for file sharing. It's your best travel partner with 30+ VPN protocols support that can keep your data safe and secure on the go.
 INSTRUCTION: >Go to First Time Setup
Product Description
Dual-band AC Router: Simultaneous dual-band with WiFi speeds up to 300Mbps (2.4GHz)+433Mbps (5GHz).
Security & Privacy: Convert untrusted networks into your own secure network by VPN. Supports 30+ OpenVPN & WireGuard VPN services.
Large Storage & Extensibility: Build-in MicroSD card slot that has a 128GB capacity. Extra storage for bringing a local drive to store your files.
Open Source & Programmable: OpenWrt/LEDE pre-installed, perfect for DIY projects.
Specifications
• WiFi Speed: 300Mbps (2.4GHz) + 433Mbps (5GHz)
• CPU: QCA9531 @650Mhz SoC
• Memory/Storage: DDR2 128MB/Flash 16MB
• Ethernet Ports: 3 ports (1 WAN, 2 LAN)
• USB Ports: USB 2.0
• Weight: 66g
Package Content
• Creta (GL-AR750) (1-year Warranty)
• Power adapter
• USB cable
• Ethernet cable
• User manual
Travel Gadget Organizer Pouch Bag is available HERE
A specially designed Wall Mount can be purchased HERE
Also available on Newegg US and Amazon US / UK / CA / DE / FR / ES / IT / NLJP / AU / SG / MX with FREE shipping
