Free shipping for select countries.
Save up to 35% Off on selected items, time limited!
Refurbished | White Mini Smart Router | Commercial IoT Applications | Pocket-sized | Travel-Friendly (GL-AR150)
by GL.iNet
Save 20% Save 20%
Original price USD24.90
Original price USD24.90 - Original price USD34.90
Current price USD19.99
USD19.99 - USD34.90
Antenna: Internal Antenna (+$0)
PoE: None (+$0)
Bulk Order
Note: The Refurbished AR150 does not come with outer packaging or cabling.
Meet White (GL-AR150) is a pocket-sized and lightweight (40g) mini travel router applicable for small enterprises and family users. It’s your best choice for internet surfing and wireless.
 INSTRUCTION: >Go to First Time Setup
Product Description
• Wireless Mobile Mini Travel Router: 40g (1.41 Oz) only, travel-sized, and compact design fits in with any pocket.
• Open Source & Programmable: OpenWrt pre-installed, DDWrt supported. USB disk is extendable.
• Large Storage & Extensibility: 64MB RAM, 16MB Flash ROM, dual Ethernet ports, UART, and 2.54mm standard GPIOs for hardware DIY.
• Security & Privacy: OpenVPN and WireGuard pre-installed, compatible with 30+ VPN service providers.
• PoE Power Supply (Optional): You can only use one power supply method at one time, either via PoE (Power over Ethernet) or micro USB cable. The PoE injector should be compatible with active or passive 48V 802.3af standard. PoE only works on the WAN port.
Specifications
• WiFi Speed: 150Mbps (2.4GHz)
• CPU: Atheros9331, @400MHz SoC
• Memory/Storage: DDR2 64MB/FLASH 16MB
• Ethernet Ports: 2 ports (1 WAN, 1 LAN)
• USB Ports: USB 2.0
• Weight: 40g
Package Content
• White (GL-AR300) (1-year Warranty)
• USB cable
• Ethernet cable
• User manual
Travel Gadget Organizer Pouch Bag is available HERE
A specially designed Wall Mount can be purchased HERE
  • Memory / Storage: DDR2 64MB / FLASH 16MB
  • Protocol: IEEE 802.11a/b/g/n
  • Wi-Fi Speed: 150Mbps (2.4GHz)
  • Antennas: Internal or external antenna
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: 1 x USB 2.0
  • Ethernet Port: 1 WAN, 1 LAN
  • Ethernet Speed: 10/100
  • Power Input: microUSB, 5V/1A
  • Power Consumption:
  • Dimension / Weight: 58 x 58 x 25mm / 40 g
  • White (GL-AR150) mini router (1-year Warranty)
  • USB cable
  • Ethernet cable
  • User manual
