Black Friday Month starts from now to November 30, 2022 with up to 30% off!
EU Local Delivery | Opal (GL-SFT1200) | EU plug
by GL.iNet
Save 14% Save 14%
Original price $49.90
Original price $49.90 - Original price $49.90
Current price $42.90
$42.90 - $42.90
Maximum quantity limit / Order: 100 units
The Opal in this link is only available for the countries listed above. If your country is not on the list, please purchase the Opal HERE.
- VAT included
- Fast delivery (Shipping from Germany)
*If customers not from upon countries place the order by mistake, we would ask for the balance or cancellation.
Opal (GL-SFT1200) is a pocket-sized OpenWrt travel router with the best value that offers superb dual-band Wi-Fi performance. It is compactly designed for portable use, which can meet the needs of wireless internet access for small businesses, small apartments, or business travelers.
Product Description
  • Dual-band Wireless Router: Simultaneous dual-band with wireless speed up to 300 Mbps (2.4GHz) + 867 Mbps (5GHz)
  • Pocket-friendly: Lightweight design(144.8g) designed for your next trip or adventure. Alongside its portable, compact design makes it easy to take with you on the go.
  • Keep your Internet Safe: IPv6 supported. OpenVPN & WireGuard pre-installed, compatible with 30+ VPN service providers. Pre-installed Tor service. Cloudflare encryption supported to protect the privacy.
  • Open Source & Programmable: OpenWrt pre-installed, backed by software repository. Allows you to install different applications, perfect for DIY projects.
*Easytethering NOT supported.
Specifications
  • CPU: SF19A28, Dual-Core @1GHz
  • Memory/Storage: DDR3 128MB / FLASH 128MB
  • Gigabit Ethernet Ports: 3 x 10/100/1000Mbps
  • WiFi Speed: 300Mbps(2.4GHz) + 867Mbps(5GHz)
  • Interfaces: 1 x WAN Ethernet port, 2 x LAN Ethernet ports, 1 x Type-C Power Input, 1 x Reset button, 1 x Mode switch
  • USB Port: 1 x USB 2.0
  • Dimension / Weight: 118 x 85 x 30mm, 145g
* GL-SFT1200 does NOT come with Micro SD card slot
Package Content
  • Opal (GL-SFT1200) (1-year Warranty)
  • User manual
  • Ethernet cable
  • 5V/3A Type-C power adapter with EU plug
PACKAGE CONTENTS
Opal (GL-SFT1200) (1-year Warranty), Ethernet cable, User manual, and 5V/3A Type-C power adapter EU +UK plug
Bulk Order
Please contact our customer service team at cs@gl-inet.com for wholesale pricing or other order related questions.
Other Purchase Channels
Amazon US
