Free Shipping On Order Over $200
EU Local Delivery | Brume 2 (GL-MT2500A) with EU+UK plug
by GL.iNet
Save 11% Save 11%
Original price $89.00
Original price $89.00 - Original price $89.00
Current price $79.00
$79.00 - $79.00
Bulk Order
Other Purchase Channels
Order on Amazon US
The Brume 2 in this link is only available for the countries listed above
- Fast delivery (Shipping from Germany)
*If customers not from upon countries place the order by mistake, we would ask for the balance or cancellation.
Brume 2 is a lightweight and powerful VPN Gateway that runs on OpenWrt v21.02 operating system. It is compactly designed to host a VPN server at home, or run SD-WAN (Site-to-Site) for small and medium-sized enterprises.
Product Description:
  • Runs on OpenWrt 21.02: Brume 2 runs fast VPN speed which allows you to access your home network away from home securely and easily. It is equipped with a USB 3.0 port to provide a significant advancement in data transfer speed and give you the flexibility to upgrade your server storage whenever you want.
  • Automatically Redirects Network TrafficPre-installed with OpenVPN and WireGuard® supporting 30+ VPN services. It automatically redirects all network traffic within the connected network to your VPN service or server, including guest devices and client devices that are not capable of running VPN.
  • Large Storage for Offline Data: With 8GByte EMMC (embedded multimedia card) storage, Brume 2 supports offline storage of data, save bandwidth and process data locally. With massive space for customized firmware installation, you can also enjoy faster device booting and system processing.
  • CPU: MediaTek MT7981B Dual-core, @1.3GHz
  • Memory / Storage: DDR4 1GB / EMMC 8GB
  • Protocol: N/A
  • Wi-Fi Speed: N/A
  • Antennas: N/A
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • USB Port: 1 x USB 3.0
  • Ethernet Port: 1 x 2.5Gbps WAN port, 1 x Gigabit LAN port
  • Ethernet Speed: 10/100/1000/2500Mbps
  • Power Input: Type-C, 5V/2A
  • Power Consumption: < 2.6W
  • Dimension / Weight: 70 x 70 x 22 mm / 157 g
  • Brume 2 (GL-MT2500A) security gateway (1-year Warranty)
  • Type-C power cable
  • Ethernet cable
  • User manual
  • 5V-2A Power adapter with a UK and EU plug
