Free Shipping On Order Over $200
EU Local Delivery | Beryl AX (GL-MT3000) with US+EU+UK adapter
by GL.iNet
Save 12% Save 12%
Original price $119.00
Original price $119.00 - Original price $119.00
Current price $105.00
$105.00 - $105.00
Bulk Order
Other Purchase Channels
N/A
Note: Please be aware that in order to fully utilize all of the features of Beryl AX, you will need to upgrade the firmware to the latest 4.1.3 version. Here is the download link.
The Beryl AX in this link is only available for the countries listed above
- Fast delivery (Shipping from Germany)
*If customers not from upon countries place the order by mistake, we would ask for the balance or cancellation.
Beryl AX (GL-MT3000) is an AX3000 pocket-sized Wi-Fi 6 wireless travel gigabit router which comes with one 2.5G WAN port and one 1G LAN port. It runs on MT7981B 1.3GHz dual-core processor. Dual band network with wireless speed 574Mbps (2.4G)+2402Mbps (5G), it is designed to support families with heavy Wi-Fi usage, and it's also compactly designed for travel use.
Product Description
【VPN CLIENT & SERVER】Beryl AX (GL-MT3000) is pre-installed with OpenVPN and WireGuard®. It automatically encrypts all network traffic within the connected network. Max. VPN speed of 150 Mbps (OpenVPN); 300 Mbps (WireGuard®)
【CUSTOMIZATION & PROGRAMMABLE】Beryl AX runs on OpenWrt 21.02 (Kernal Version 5.4) firmware, supporting more than 5,000 ready-made plug-ins for customization. Simply browse, install, and manage packages with our no-code interface within Beryl AX's Admin Panel.
【DFS CERTIFICATION in US, UK, EU & Japan】Beryl AX is approved to use DFS (Dynamic Frequency Selection), letting the router's 5GHz network use additional frequencies normally reserved by military, satellite, and weather radar applications.
PROTECT YOUR NETWORK SECURITY】Beryl AX supports WPA3 protocol-Preventive measures against password brute-force attacks; DNS over HTTPS & DNS over TLS-Protecting domain name system traffic and preventing data eavesdropping from malicious parties; IPv6-Built-in authentication for privacy protection, eliminating the need for network address translation.
Specifications
  • CPU: MT7981B Dual-core Processor @1.3GHz
  • Memory/Storage: DDR4 512MB / NAND Flash 256MB
  • Ethernet Ports: 1 x WAN Ethernet port; 1 x LAN Ethernet port
  • WiFi Speed: 574Mbps (2.4GHz), 2402Mbps (5GHz)
  • Interfaces: 1 x WAN, 1 x LAN, 1 x Type-C Power Input, 1 x Reset Button, 1 x Toggle button
  • USB Port: 1 x USB 3.0
  • Dimension / Weight: 106 x 83 x 33mm / 196g
  • Memory / Storage: N/A / N/A
  • Protocol: IEEE 802.11a/b/g/n/ac/ax
  • Wi-Fi Speed: 574Mbps (2.4GHz), 2402Mbps (5GHz)
  • Antennas: 2 x retractable external Wi-Fi antennas
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: N/A
  • Ethernet Port: 1 x WAN Ethernet port 1 x LAN Ethernet port
  • Ethernet Speed: WAN Port: 10/100/1000/2500Mbps LAN Port: 10/100/1000 Mbps
  • Power Input: Type-C, 5V/3A
  • Power Consumption: <8W
  • Dimension / Weight: 106 x 83 x 33mm / 196 g
  • Beryl (GL-MT3000) (1-year Warranty)
  • 2×Ethernet cable
  • User manual
  • 5V/3A Type-C power adapter with US+EU+UK plug (default) or AU plug
