SD3077 RTC Module
Sold out
$8.00
  • Real-time Clock (RTC) Module for GL-AR150 router
  • Note: CR2032 coin battery is included.
  • This item unable to ship out individually, usually it should be install to our product before shipment, if you prefer to order RTC only, we will remove the battery, but you can find the battery CR2032 from your local store, the price will be the same as the battery include.
