Collie (GL-X300B) Industrial 4G Gateway | GPS Version
Maximum quantity limit / Order: 100 units
Collie (GL-X300B) is an industrial cellular gateway designed to operate under high temperatures and scenarios with potential physical hazards. The GPS version of Collie for providing location tracking data.
Any request for the optional of the additional 128MB Nand Flash, please contact sales@gl-inet.com.
INSTRUCTION: >Go to First Time Setup
Product Description
- Stable CPU: Collie comes with a Qualcomm QCA9531 chipset. It provides stable performance and is also commonly used within the industry, which is perfect for industrial users to avoid breakdown.
- Built-in 4G LTE Module: Collie comes with a standard SIM card slot that supports the 4G LTE network. It can move into 4G LTE wireless network if the Ethernet Internet fails, in order to ensure constant data transmission in the critical facilities. Not support Verizon Network in the US.
- Built-in Watchdog: The Built-in hardware watchdog ensures the stability of Collie. It’s dedicated hardware that can detect and trigger a processor reset if necessary.
- GPS Module: GL-X300B-GPS provides location data accessible on GoodCloud, and customisable to develop long-range asset tracking applications such as viewing public transport movement.
- Easy Configuration: Supports AT command, manual/automatic dial number, and signal strength checking in our new admin panel for better management and configuration.
- Open Source & Programmable: OpenWrt pre-installed. Perfect for developers or IoT integration development.
- High Security: Supports 30+ VPN service providers, including OpenVPN & WireGuard. Cloudflare and NextDNS supported.
- Compact Design: Its aluminum alloy shell, optional wall-mounted design, and wide range of operating temperature are designed for easy installation, storage, and operation in tough industrial environments.
Specifications
GPS Version:
- CPU: QCA9531, @650MHz SoC
- Memory/Storage: DDR2 128MB / FLASH 16MB
- Ethernet Ports: 2 x 10M/100M Ports (1WAN, 1LAN)
- WiFi Speed: 300Mbps (2.4GHz)
- Watchdog: Hardware Watchdog
- Interfaces: 1 x Power DC, 1 x Standard SIM Card Slot, 1 x Reset Button
- Antennas: 2 x WiFi Antennas, 2 x 4G Antennas, 1x GPS Antenna
- Wi-Fi Protocol: 802.11 b/g/n
- Power Supply: 9~35VDC
- Dimension: 104 x 113 x 28mm
Package Content
-For GPS Version
- Collie (GL-X300B) X 1 (1-year Warranty)
- Ethernet cable X 1
- User manual X 1
- External 4G antenna X 2
- External Wi-Fi antenna X 2
- External GPS antenna X 1
- Terminal block (Green) X 1
- Plastic wall plug and screw set for wall installation X 1
- Din rail clip and screw set for DIN rail installation X 1
- Power adapter set (US, UK and EU plug) X 1 (three-months Warranty)
PACKAGE CONTENTS
Collie (GL-X300B) X 1 (1-year Warranty), Ethernet cable X 1, User manual X 1, External 4G antenna X 2, External Wi-Fi antenna X 2, External GPS antenna X 1, Terminal block (Green) X 1, Plastic wall plug and screw set for wall installation X 1, Din rail clip and screw set for DIN rail installation X 1, and Power adapter set (US, UK and EU plug) X 1 (three-months Warranty)
Bulk Order
Please contact our customer service team at cs@gl-inet.com for wholesale pricing or other order related questions.
Other Purchase Channels
N/A
