Free Shipping On Order Over $100
Bundle Offer | Slate AX (GL-AXT1800) Gigabit Wireless Router + Power Supply Adapter
by GL.iNet
Save 27% Save 27%
Original price $161.99
Original price $161.99 - Original price $161.99
Current price $119.00
$119.00 - $119.00
Bulk Order
Other Purchase Channels
Order on Amazon US
This item includes a GL-AXT1800 and a set of power adapters for AXT1800.
Slate AX is our first Wi-Fi 6 travel router that comes with IPQ6000 1.2GHz quad-core processor. With the latest Wi-Fi 6 technology, you can enjoy more capacity for connected devices and faster wireless speed on the road or at home.
Product Description:
  • OpenWrt Compatible Wi-Fi 6 Travel Router: Merging Wi-Fi 6 Technology (OFDMA, MU-MIMO) with an open-source system, and supporting Openwrt 21.02* (*Kernel version 4.4.60), you can customize your router and install applications based on your preferences.
  • Portable and Powerful Wireless Router: Slate AXT1800 provides Up to 574Mbps (2.4GHz) + 1201Mbps (5GHz), you can browse at faster speeds while on the go. Enjoy lower buffering time and an efficient connection with our portable router.
  • DFS (Dynamic Frequency Selection): For Europe and US provides access to network channels that aren't normally used by others; With DFS Certifications for US, UK, Europe & Japan* (5G WIFI Band 2(5250Hz-5350Hz) is currently unavailable in Japan)
  • Strengthens Internet Security: The powerful CPU provides you a high-speed VPN clients' performance: OpenVPN up to 120Mbps, WireGuard®VPN up to 550Mbps*, compatible with 30+ VPN service providers. Slate AX allows you to browse securely when on public wi-fi, work remotely when abroad, and access geo-restricted sites.
  • Smooth Video Streaming and Fast File Transfer: With USB 3.0, you can exploit the tethering function by sharing your mobile's internet with the router; Add extra storage to your router through NAS and share files and data to your network; With a TF card storage that supports up to 512GB, Slate AX is ideal for file sharing and customizing your device through downloading firmwares and applications that suit your needs.
  • CPU: IPQ6000 Quad-core,@1.2 GHz
  • Memory / Storage: DDR3L 512MB / NAND Flash 128MB
  • Protocol:  IEEE 802.11a/b/g/n/ac/ax
  • Wi-Fi Speed: 600Mbps (2.4GHz), 1200Mbps (5GHz)
  • Antennas: 2 x undetachable external Wi-Fi antennas
  • Cellular: N/A
  • Battery: N/A
  • TF Card Slot: 1 x microSD card slot
  • USB Port: 1 x USB 3.0
  • Ethernet Port: 1 x WAN, 2 x LAN
  • Ethernet Speed: 10/100/1000Mbps
  • Power Input: Type-C, 5V/4A
  • Power Consumption: <8.75W
  • Dimension / Weight: 125 x 82 x 36mm / 245 g
  • Slate AX (GL-AXT1800) Wireless Router (1-year Warranty)
  • Power adapter & converters (US, EU, UK&AU)
  • Ethernet cable
  • User Manual
  • Power adapter with US (default) or UK or EU or AU plug
