Click HERE to enjoy an extra 20% OFF for the routers on our Early Black Friday Offer from 25, Oct - 10, Nov.
Amarok (GL-X1200) Industrial IoT Gateway | Dual-band | 4G LTE
by GL.iNet
Save 36%
Original price $359.00
Current price $229.00
 Amarok (GL-X1200) is a powerful and stable 4G IoT gateway designed for industrial users. Because of its open-source features, it can be used as an integrated platform for developers and IoT integration development. It also comes with an industrial-grade standard with 5 gigabit Ethernet ports, PoE, 2 SIM card slots, a TF card slot, and a USB 2.0 port.
This router is designed for industrial and enterprise users. Please email us via cs@gl-inet.com if you have any questions.
 INSTRUCTION: >Go to First Time Setup
Product Description
Dual-band 4G LTE Gateway: 300Mbps(2.4GHz)+867Mbps(5GHz) with built-in 4G LTE module.
Enterprise-Grade Standard Hardware: 2 x CAT4/6 LTE modules, 2 x SIM card slots, 1 x TF card slot, 1 x USB2.0 port, PoE, 5 x Gigabit ports
Open Source & Programmable: OpenWrt pre-installed. Perfect for developers or IoT integration development.
VPN Client & Server: Compatible with 30+ OpenVPN and WireGuard VPN services.
Specifications
• WiFi Speed: 300Mbps(2.4GHz)+867Mbps(5GHz)
• CPU: QCA9563, @775MHz SoC
• Memory/Storage: DDR2 128MB/FLASH 16MB + 128MB
• Ethernet Ports: 5 ports (1 WAN, 4 LAN)
• Card Slots: 2 x SIM card slots, 1 x MicroSD card slot
• USB Ports: USB 2.0
• Weight: 1360g
Package Content
• Amarok (GL-X1200) (1-year Warranty)
• 2 x Quectel 4G module pre-installed
• 4 x 4G LTE external antennas (2 dBi), 2 x 5G&2.4G external antennas (5 dBi), 1 x GPS external antenna
• Ethernet cable
• User manual (in PDF)
• Power adapter (48V/1A is default to support PoE function, 12V/3A is optional and not support PoE)
